Brake lights not working
Before some smartass says use search function. I have and googles to no avail.
Brake lights don't work. Every other light works though.
Replaced bulbs.
Replaced fuse under hood.
Replaced brake light switch.
I just got it so no spoiler with third light so I'm not sure where the harness is located. Which may be the problem.
94 hb
Replaced bulbs.
94 hb
Seriously though, I am not sure as I have never checked on my Honda, but I had this problem with another car from a while back. Check the brake switch at the pedal - you know the part that completes the cicuit when you press the pedal. Perhaps there is a problem there.
I would say that if NEITHER of the brake lights are working there is a good chance that no electric is not even getting there either.
Mike
wrong you do, wlamart sells them for 14$ or 20$ for the high grade
Bluhonda93
Apr 1, 2013 05:20 PM
gunaa
Oct 22, 2009 11:36 AM
chrisroug
Oct 2, 2006 11:36 AM
