brake noise
Old May 8, 2007 | 07:31 PM
aerodragon's Avatar
Default brake noise
hi,
I just got a 2005 Civic EX and found out that once in a while I could hear that the brake makes "clunking" noise (intermittently shows up when pushed lightly). Does anyone ever experience the same thing? On a side note, I never drove a civic before.
Thanks
Old May 8, 2007 | 07:44 PM
Live_4it's Avatar
Default RE: brake noise
sounds like theres something wrong with your caliper. Either the master cylinder isn't working properly or your brake pad is broken or something stuck in it.
Old May 8, 2007 | 07:46 PM
Thefbomb13's Avatar
Maybe his Rotor is warped ?? Does your break pedal pulse when you step on it?
Old May 8, 2007 | 07:48 PM
aerodragon's Avatar
thanks for the replies.
maybe I didn't explain it clearly. is it normal on a civic when you push on the brake pedal, once in a while, you could feel it's a dual stage breaking (it will brake firmly but after you push the brake lightly, you could feel another deeper push that makes a little noise)?
no, it doesn't pulse.
Old May 8, 2007 | 07:53 PM
Live_4it's Avatar
Oh, it could be your ABS kicking in. Does it only do it when your going fast and you brake hard?
Old May 8, 2007 | 07:55 PM
aerodragon's Avatar
not always at high speed, sometimes at low speed also and the dealer couldn't duplicate it earlier (very short drive) but mentioned about "T" which I am not sure what it means.
Old May 9, 2007 | 06:11 AM
Fiirkan's Avatar
If it only happens when braking slowly, if you have an auto tranny it could be the transmission shifting down.
Old May 9, 2007 | 01:35 PM
Drunkgoose's Avatar
I think i know what you're talking about, it happens on my 2000 civic dx, happens sometimes, and only at very low speeds, or sometimes even when i'm just standing still, i'll push in the brake and it will make a "clunk" sounds like it comes from the back of the car though... As far as i know nothing is "wrong" with my car or the breaks, but i have no idea why it does that, everything works fine though.
Old May 13, 2007 | 04:59 PM
Tim706's Avatar
I'm willing to bet the clunking noise is a ball joint sliding in the socket, everytime you step on the brake it puts torsional forces on your whole suspension assembly which cause the steering knuckle to twist, whacking the ball joint back and forth. Bring your car to a mechanic and have them check the front end.
Old May 26, 2007 | 06:57 PM
jeff_o's Avatar
i have an 05 civic lx w/o the ABS. sometimes when i brake i feel a click or sometimes 2-3 clicks on the brake pedal. i dunno if this is what you're talking about. but i think most honda's have that problem. I had a honda city back home and i also get the same clicking feel when applying the brake. but overall the braking does not get affected... i still get the same stopping power... i just dunno what that click is.. but i feel it's from the calipers.
