brakes acting ignorant
Old Jan 13, 2008 | 08:11 PM
GangstaMas1's Avatar
Default brakes acting ignorant
After installing new pads the pedal goes almost all the way to the floor what could that be?
Old Jan 13, 2008 | 08:17 PM
Default RE: brakes acting ignorant
Your front caliper or rear wheel cylinder has a leak. Alternatively, your brake master cylinder has failed. Look for brake fluid leaks.
Old Jan 13, 2008 | 08:19 PM
that makes sense thanks
Old Jan 13, 2008 | 08:33 PM
The location of the brake fluid leak will be highly informative.
Old Jan 14, 2008 | 09:23 AM
Firehawk989's Avatar
I think its far more likely that you just need to bleed your brakes, especially if they were working fine before you changed the pads. The tiniest bubble of air in the lines can cause these symptoms, happened to me when I changed my pads and rotors. You just go to the auto parts store and buy a brake bleed kit for like $10 or $15 bucks and follow the instructions, its pretty simple. Buy some Honda brake fluid as well since you might use up a bit when you bleed them.
Old Jan 14, 2008 | 09:50 AM
reconstyle's Avatar
A brake bleed kit? All you need is a bottle of brake fluid, a piece of tubing, and a friend.
Old Jan 14, 2008 | 09:56 AM
My04Civic's Avatar
Administrator
bleed the brakes...i had the same problem...so go back and keep bleeding. it sucks, i know. you need 2 people
chism111
Jul 24, 2007 01:16 PM
Ben
Oct 25, 2006 08:09 AM
ahhsimon
Jun 14, 2006 09:52 AM
Ben
Apr 24, 2006 01:09 PM
faceless_civic
Nov 17, 2004 10:19 PM
