broken bolt
the bold from my downpipe is broken. Half of it is still in there and cant take it out. even with a impact wrench and a reg. wrench. I tried but i cant get it out. Any suggestions for me, i dont want to take it in to the muffler shop. well hope that helps. thanks.
I'm thinking that you could drill out the bolt/stud that is in the pipe and put in a bigger bolt with a washer and a nut. For next time, WD-40 is your friend, i learned that the hard way.
whats a down pipe? the only down pipe that i know of is on turbo cars...do you mean off of your exhaust manifold? is that the head, or the end? and is it in a threaded piece, or is it just rusted in place?
Go to an autoparts store and bet one of those blow torches, heat the bolt up just enought so that it starts to turn red... but DO NOT let it melt..then use a wrench and vouala it should come out.... in theory
^ yeah i was refering to the propane ones... it was mainly an idea that popped into my head just then i didn't really think about it... and when i said starts to turn red, i meant that once you see red developing to stop heating it.. and the propane ones are only like $15-20.. so it isn't like it is a big investment for it... worth a shot i'd say
Coat it in PB Blaster, let it sit for a few minutes, then heat with a torch and try the impact gun again. If that doesn't work, your only other options are drilling, or an easy out, and those things are teh ghey
Thanks guys. Ill try that after school. if it doesnt work then ill just go to milwaukee and tell my uncle to see what he can do. I have to go to milwaukee anyways. Well thanks for the tip. Will sure try some.
ORIGINAL: Fiirkan
