SRS Issue!!
Old 05-13-2008, 04:59 AM
johnz826's Avatar
Default SRS Issue!!
Just randomly last week, my SRS light came on when i started my car at my buddies place. The car was resting for about 5-10 minutes before i started it back up and then the light stayed on. Any idea what this could be about? it's a 2001 LX. has 90k on the odometer. Plus i asked how much it would cost to have it checked and the dealer ship wants 100 bucks just to plug it in and check it!!! What a rip off. Any help would be great.
Old 05-13-2008, 07:38 AM
mundy5's Avatar
Default RE: SRS Issue!!
I'm sure there are many ways to deal with this type of issue. Others can correct me if I am wrong, but usually the srs light code is not detected by these obdII scanners sold over the counter. Maybe a parts store has a more sophisticated scanner that can read the srs code.
The rate quoted by your dealer is pretty close to standard. I've heard $90 usually to read codes. So the quote is pretty close.
Old 05-14-2008, 05:20 AM
johnz826's Avatar
Yea, i brought it to a shop and they tried, didn't work. They said Honda only has the scanner to read the codes, i'd be lucky if i found a shop that had one....ugh it's annoying lookin at that light.
Old 05-14-2008, 09:37 AM
Big EZ's Avatar
mine is on in my 98, it is annoying at first but you get use to it.
Old 05-14-2008, 09:53 AM
mundy5's Avatar
if either of you really are annoyed, you can remove the fuse and it will turn off although your air bags won't deploy, but with the light on, it might not deploy anyway. another option is to remove the cluster and take out that bulb. of course, neither of these solutions actually deal with the main issue which is something amiss with the air bag system...
Old 05-14-2008, 11:39 AM
ORIGINAL: mundy5
On my 97 I removed the fuse and the light stayed on....maybe I got the wrong fuse?
Old 05-14-2008, 02:34 PM
mundy5's Avatar
probably did.
mudhenFUF
01-16-2023 08:43 PM
fivebells
08-09-2014 06:10 PM
brokenarmboy19
09-28-2008 03:13 AM
ettrump
02-23-2005 05:28 PM
Quick Reply: SRS Issue!!
