A/C goes in and out of blowing hot air
Old Jun 4, 2012 | 10:28 AM
ncamo's Avatar
Default A/C goes in and out of blowing hot air
My A/C last summer started blowing hot air at random times. It is doing it again this summer. It only does it when I have it working on full blast. It will be blowing strong and cold for awhile and then switches to hot or outside air (I live in AZ so all air is HOT) for awhile (a minute or so) then switches to cold. What does this mean?
Old Jun 5, 2012 | 05:57 AM
When it is not cooling, pull over and look under the hood (engine still running and A/C button pressed). Note if the condenser fan is running, and if the compressor is engaged. If you find the fan running but the compressor not engaged, you probably need to adjust the clutch gap. It could also be the compressor relay.
aztecaa
Nov 4, 2013 10:53 AM
jenkent527
May 1, 2013 02:44 PM
sstimothy
Jun 22, 2012 06:57 AM
dnspare
24
Jun 21, 2009 10:32 PM
mill$civic
Sep 22, 2006 10:33 PM
