A/C Intermittent Cooling
Summer is here.
Problem is that the A/C cools when car is first used for the first 30 minutes or so and then stops cooling. I put in a can of refrigerant the other day and drove the car 25 miles during the heat of the day to run some errands. A/C worked great. Then on the way home A/C wasn't cooling very well. I hooked up a A/C manifold gauge this morning and here is what I found: Static pressure at 90 F ambient temperature: Low side = 85 psig High side = 90 psig Load pressure at 1,500 rpm Low side = 22 psig High side = 230 psig From pressure temperature tables it appears that the system is OK but does anyone see issues with these readings? |
What year Civic?
When the A/C won't cool well, dose the condenser fan fail to run or does the compressor clutch fail to engage, or both? |
Originally Posted by RonJ
(Post 716624)
What year Civic?
When the A/C won't cool well, dose the condenser fan fail to run or does the compressor clutch fail to engage, or both? I will have to pay attention next time and give you a definitive answer. :) |
