A/C Intermittent Cooling
Summer is here.
Problem is that the A/C cools when car is first used for the first 30 minutes or so and then stops cooling.
I put in a can of refrigerant the other day and drove the car 25 miles during the heat of the day to run some errands. A/C worked great. Then on the way home A/C wasn't cooling very well.
I hooked up a A/C manifold gauge this morning and here is what I found:
Static pressure at 90 F ambient temperature:
Low side = 85 psig
High side = 90 psig
Load pressure at 1,500 rpm
Low side = 22 psig
High side = 230 psig
From pressure temperature tables it appears that the system is OK but does anyone see issues with these readings?
Low side = 85 psig
High side = 90 psig
Low side = 22 psig
I will have to pay attention next time and give you a definitive answer.
Rabbit
Aug 9, 2014 03:28 PM
importmech
Oct 14, 2004 09:25 PM
92, 99, ac, car, civic, compressor, condenser, cooling, cools, fan, honda, intermittent, intermittently, pressure, static
