a/c not working
Old Jul 21, 2009 | 02:57 PM
import4life's Avatar
Default a/c not working
I have a 93 honda civic ex and when i purchased it, the previous owner said it had a leak so i decided to put some freon back in and noticed that the compressor doesn't kick on and the condenser fan won't turn. Where can i begin to check to find out where my problem is. I checked all the fuses and all seem to be good. I also tried jumping the pressure switch and nothing happens. But i did notice that when i turn the a/c button on from inside the car the idle goes up. Please help
Old Jul 21, 2009 | 05:57 PM
Here's where to start:
Is fuse 35 (hood) or 13 (dash) blown? If not, the diagram shows you the location of the condenser fan relay and the compressor clutch relay under the hood.
To test the fan, remove its relay and use a jumper wire to connect the WHT wire to the BLU/BLK wire in the connector. Does the fan run?
To test the compressor clutch, remove its relay and use a jumper wire to connect the WHT wire to the red wire in the connector. Do you hear the compressor engage (click sound)?
Old Jul 21, 2009 | 06:32 PM
ok thanks i will check it tomorrow. i will let you know
Old Jul 22, 2009 | 10:05 AM
ok i found that the fuse under the hood is blown. replaced it and now my compressor kicks on but the condenser fan still isn't working.
Old Jul 22, 2009 | 10:15 AM
Do you measure battery voltage to body ground at the WHT wire of the condenser fan relay? If you jump the fan relay (connect WHT wire to BLU/BLK wire in the connector), does the fan run? If all tests fine, then the fan relay may be bad. Save money by testing it before replacing.
Old Jul 22, 2009 | 02:41 PM
ok ill try that and let u know
Old Jul 22, 2009 | 04:57 PM
ok i do have battery voltage at the white wire and when i jump the white and blu/blk wire the fan looks like it attemps to turn but something is preventing it from turning, like if its stuck. i tried turning it by hand and it doesn't budge freely. is it suppose to be like that?
Old Jul 22, 2009 | 05:00 PM
Sounds like the condenser fan motor has seen a better day. Replace it.
Old Jul 22, 2009 | 06:27 PM
so with the condenser fan not working that will cause the air not to cool even though the compressor works?
Old Jul 22, 2009 | 06:50 PM
The A/C probably would not blow cold with the engine idling if the condenser fan doesn't work. It probably would if the car were moving. If the latter isn't currently true for your car, then there may be an additional problem. Fix the fan and then go from there.
