A/C Surging Problems 93 Civic Ex 1.6l
Old Jul 10, 2011 | 12:44 PM
lunger's Avatar
the low side seems a little high with your high side readings. you might want to clean your condenser and you will notice a little better cooling capacity. if it is clogged with debris then it degrades it's ability to dissipate the heat.
Old Jul 10, 2011 | 02:37 PM
You must charge by weight to know where you stand. It's a small system with little tolerance for overcharging. Lunger has a good point about dirt in the condenser fins. Also the fins tend to get munched up from road debris.
Old Jul 11, 2011 | 04:18 PM
lunger's Avatar
I usually go 2 to 2.25 times the ambient temp for the high side pressure when servicing to get the proper amount in system. However the low side seems a tad bit high. I would change the expansion valve personally, if the condenser is clean and free of debris.
Old Jul 11, 2011 | 05:04 PM
Originally Posted by celrod05
I did pull vacuum on the system but only for about 30 min. My pump would not pull past 15in for some reason.
Full vacuum is about 30 in, so you clearly did not remove all of the air. In addition, you should pull full vacuum for about 2 h to be sure you have fully evacuated the system.
Civic4952
Nov 28, 2011 10:31 AM
raymondscoalition
Feb 11, 2009 09:01 PM
chadzeilenga
Mar 20, 2007 08:10 AM
jdhonda
Nov 21, 2006 02:57 PM
chicken_buster
Jul 30, 2005 12:16 AM
