can i use my ecu with b18???
Old Sep 25, 2007 | 04:02 PM
colby_666's Avatar
Default can i use my ecu with b18???
i just removed a b18 from a 93 civic and im going to put it in my 98 civic but i thought that you had to use a different computer to run a different motor, but the car was i removed the motor from was using the stock computer. Can i use my computer from my 98 civic ex with the b18??? thanks
Old Sep 30, 2007 | 05:12 AM
colby_666's Avatar
Default RE: can i use my ecu with b18???
i already searched this and found nothing, i thought that i would have to get a new computer but the 93 civic was using the stock computer with the b18?????
Old Oct 26, 2007 | 03:24 AM
jdmitrswapped's Avatar
Most likely not man. That b18 is odb2. The 93 civic is either using an integra ecu or a harness to plug that b18 into the civic's older ecu. Also running a civic ecu with a larger integra motor is a really bad idea. A stock ecu is programmed by the factory to give the right amount of air/fuel to the motor it's designed for. It won't be able to compensate enough air/fuel to properly run a larger motor so you wont see the b18's potentialand also risk running too lean or too rich.
But if you tuned if afterwards it then I see no problem with your setup.
What is the code on the ecu from the 93?Does that B18 have a vtec head (is it vtec or non-vtec)?
Old Oct 26, 2007 | 05:27 AM
mxs's Avatar
mxs
which model civic and which model B18? and what's the code on the ECU?
Old Oct 26, 2007 | 09:26 PM
my_hidden_romance's Avatar
mxs is right... and that new guy up there is very wrong... obd2 started in 96.. which means that the 1.8 engine would have to be from a 96 or higher integra...
most likely due to the ability to find b18b/a and early model c engines.. its probably obd1.. which means that depending on the ecu u could run it...
p28 and p72 are good ecus for b18s... well at least for gs-r.s but as long as the wires are right you can do just about anything with hondas.. thats why k series engines are soo easy to swap
snediker.jake
Aug 14, 2009 03:28 PM
Captain_Sl0w
Aug 19, 2008 06:41 PM
rramsey
Jan 3, 2008 05:47 AM
FlipHKD720
Oct 13, 2006 09:43 PM
Illholddamoney
May 3, 2005 12:32 AM
