can i use a non vtec block w/ a vtec head
i have a 1996 honda civic ex w/ a vtec motor. i need a block and found one(1998) but it is not a vtec engine can i use this block w/ the vtec head i have?
RE: can i use a non vtech block w/ a vtech head
neither are a vtec e
RE: can i use a non **** block w/ a **** head
welcome to the wide world of "mini me's" they are difficlt and not the easiest thing in the world. but they can be done.
ok as long as the block is from a D series motor, and the head if from a D series then yes you can swap them
I'm guessing you found a Y7 block? I would consider cleaning out any sludge you may find in the oilpan before you put it in. Find a minime writeup and read the whole thing.
yea it can be done theres nothin to it realli just changing the belt thats about it then you will have to find some one to run the v-tech to the ecu it you dont want to change the wire harness and yes u need a v-tech ecu like a p-28 or something ok
well, if you've all ready got a vtec car, and just need a block, it'd be as simple as changing the blocks, as the car is all ready set for vtec... lucky you
still not the easiest process ever, but easier because you have less to do. in a 98, i'd assume a D16Y7 |
RE: can i use a non vtec block w/ a vtec head
it can be done ,will have to plug vtec oil feed passeges and mill the head to make it even, find seperate oil pressure feed for the contol solinoid, should be able to find complete build on mimi me swaps
| All times are GMT -8. The time now is 12:05 AM. |
