Can Some1 Help w/ Backfiring?
When was the last time you changed your spark plugs? Do you have the right kind in? Go with the kind stated in your manual prolly NGK copper, unless your running boost. Could also be bad gas. I would also run seafoam and or fuel injector cleaner to clean it up a bit, carbon buildup can have something to do with it. Replace the distributor cap and rotor along with the plug wires and i'm pretty sure with these changes the backfiring will be gone.
ReSpEcT90210
Jul 6, 2007 07:37 AM
rdas45
May 29, 2006 11:15 AM
