Can't find what is wrong
Old Feb 25, 2007 | 03:18 AM
tattoolab's Avatar
Default Can't find what is wrong
ok, My car is a 91 civic hatch. It starts fine but after 15 mins or so i lose all my power and,if i rev it, it pops at 3500rpms like i have a revlimiter but i don't have one. I have tryed changing my hole intake,dis cap and roter,cleaned my injection.I thought it mit be my ECU. PLEASE HELP
Old Feb 25, 2007 | 09:42 AM
phil0975's Avatar
Default RE: Can't find what is wrong
Have you done any electrical work to the motor? Are all cylinders firing correctly? i.e. timing or fouled plugs
Old Feb 25, 2007 | 11:28 AM
fglaustin's Avatar
when was the plugs and plug wires changed
Old Feb 25, 2007 | 12:56 PM
MartinMalley's Avatar
That sounds like the Main Relay. When they go, it takes about 15 minutes for it to heat up, then it shuts off the fuel pump.
http://techauto.tripod.com/mainrelay.htm
Old Feb 25, 2007 | 01:35 PM
tattoolab's Avatar
no i have not done any wireing work yet.and the plugs and wires are new.
were is the main relay at? if that was it would other stuff not work?
Old Feb 25, 2007 | 02:20 PM
fglaustin's Avatar
what other stuff does not work;
it is under the dash up against the left side kick panel about where your left knee is when sitting in the driver's seat (all the way to the left of the knee)
Old Feb 25, 2007 | 04:04 PM
tattoolab's Avatar
no everything works great.Thanks i will try that
Old Feb 26, 2007 | 08:28 PM
b8teen's Avatar
i had the same problem, it was the tdc sensor. is there a cel?
Old Feb 27, 2007 | 04:57 AM
tattoolab's Avatar
what do u mean cell.and were is tdc at?
Old Feb 27, 2007 | 12:31 PM
the_turtle's Avatar
CEL = check engine light. is the tdc sensor the crank sensor that sense Top Dead Center?
