can't open my rear door
Old Nov 7, 2008 | 08:26 PM
bigmikew1's Avatar
Default can't open my rear door
my handle has been broken on the outside of my passenger side rear door so i can only open it from the inside. my cousin put the child safety lock on and now i cant open the door at all. i was gonna take off the door panel from the inside but the door is locked so i cant take it off. now im stuck. is there a way to bypass the child safety lock? wat can i do?
Old Nov 7, 2008 | 08:41 PM
What year?
If you remove the inner handle, you may have access to the lock rod.
Old Nov 9, 2008 | 04:32 PM
bigmikew1's Avatar
its a 93
Old Nov 9, 2008 | 04:53 PM
Old Nov 9, 2008 | 05:37 PM
gwl's Avatar
gwl
You may have go to body shop to see if they can figure out how to open your door. Have you tried rolling down the window and move the child safety lever between the window slot?
It will be nearly impossible not to damage your door panel when you try to remove it with the door stuck shut.
Old Nov 9, 2008 | 05:58 PM
ashcheerit2000's Avatar
Hey i have the same problem all you need is a thin wire and where the door handle on the outside of the car the child saftey lock is right below so go through the crack of the door and unlock it.. i did it without hurting the paint and only took 2 mins if that
mrossi22
Feb 4, 2015 10:28 AM
relentlesstech
May 30, 2012 05:40 AM
cmpr611
Jul 21, 2010 12:10 PM
Karado58
Nov 24, 2009 03:49 PM
Lambo Civic
Jun 1, 2008 03:11 PM
