Car won't shift
Old Feb 11, 2008 | 06:49 AM
therickus's Avatar
Default Car won't shift
Hello, I have been reading the forum for a couple weeks now, but haven't found my problem. So i decided to register and post. I have a 2004 Civic Si, with 60,000 miles. I drove to Indianapolis from Rochester, NY, and on my way back, I tried shifting down from 5th, but the shifter would not move. I came to a stop at the nearest gas station, where I turned my car off. When the car is off, I can shift into any gear, and start my car and run in that gear, but I cannot change gears when the car is on. My car has sat for 3 weeks as I have tried determining the problem. Any suggestions?
Old Feb 11, 2008 | 09:24 AM
Default RE: Car won't shift
Does the clutch work? In particular, can you push the clutch pedal down and have the car stopped in gear with the engine running?
Old Feb 11, 2008 | 09:46 AM
therickus's Avatar
Default Clutch
The clutch will work enough to keep me from rolling forward or backwards in reverse. It does grind though(didn't start until after the problem first occurred). I am currently in the process of replacing the clutch, but I am fearful that it is not the only problem.
Old Feb 11, 2008 | 11:22 AM
Default RE: Clutch
well it might be a problem with the syncros if its grinding...
Old Feb 11, 2008 | 01:04 PM
Default RE: Clutch
If the clutch drags at all, as it sounds like it does, it will be very hard to shift into gears with the engine running. Before taking the clutch itself apart, check the fluid level in the hydraulic system.
Old Feb 18, 2008 | 11:56 AM
therickus's Avatar
Just so that everyone knows, the problem was that a spring broke on my clutch(I don't drive the car hard, so I don't know how that happened). The spring was then locking into the flywheel, which wouldnt allow me to shift my car while it was on and spinning.
theRDRman
Jan 2, 2012 08:37 PM
samt
Feb 27, 2008 03:23 AM
rydnlow1120
Jul 25, 2007 01:14 PM
mybrokenblinker
Oct 30, 2006 10:29 PM
grnrivergirl
Sep 1, 2005 09:12 PM
