Car won't start, distributor looks fine
My car won't start, engine cranks, butit still won'tturnover. It's doing the same thing when my distributor went out. I replacled my distributor 6 months ago.[/align][/align]Starter is fine[/align]Checked and I'm getting a spark[/align]Checked all my fuses[/align]Replaced my spark plug wires (they were old)[/align]Check the spark plugs[/align]I'm getting Fuel[/align]The Battery is good[/align][/align][/align]Some one told me it might be the Ignition module[/align][/align]I just want to make sure before I start shelling out some cash for something I don't need[/align][/align]*before replacing the wires, I tested for a spark and I took out the fist wire located by driver side, it almost seemed to want to start. But when I put it back it just did the same old thing and wouldn't turn over, I found this a little weird*[/align][/align]Any suggestions?[/align][/align]
RE: Car won't start, distributor looks fine
So you DO have spark?
I would try to crank it, then pull your "F/I Return" line off to see if there is fuel in it. It's located behind/under the fuel rail towards the drivers side. That, imo, is the best way to check for fuel without buying a fuel pressure guage.
Have you tried jumping the car? At one point I thought that I wasn't getting spark, but it turned out that it was just a really weak spark. Jumped it with the wife's car and she fired right up.
You can try cleaning the iat sensor by spraying it with some throttle body cleaner. That should not stop your car from running though, it would just turn on the MIL. Go back over what you've done, because it's most likely the fuel or spark, the only other thing it would be is compression. Fuel + Spark + Compression = a firing cylinder, even if the engine isn't running properly. Since it was running before and now won't start at all it has to be a cause effecting all the cylinders equally, that rules out an individual wire, plug or injector, as the car would run but with a misfire. Had you touched anything under the hood since the car was last running? Just because you smell fuel doesn't mean it has the right pressure to be running, it's hard to say without a pressure gauge.
Anyways, double check that you are getting a good spark, from the plug wires, not just the coil. Take the cap off and inspect the rotor to be sure it is spinning. Also, check the fuel pressure regulator, check that the vaccuum line coming off of it is not pinched, split or damaged. Try starting with the vaccuum to the regulator disconnected just to see if anything happens.
Also, when you're cranking the engine, does it sound like it always does? Like the uneven whir that every car makes, or does it sound like an even whine? If it sounds too even then it's possible you're not getting compression, and the likely cause would be a timing belt failure.
Again, look for causes that would effect all the cylinders, not just one, as the engine died, not misfiring so it's a common problem for all four cylinders.
FD3Savage
02-07-2021 02:42 PM
brandonkf4oar
07-07-2013 05:35 AM
rcherr642z
08-21-2008 01:20 PM
forrealb50
15
11-12-2006 01:52 PM
Liebers19
12
10-03-2006 12:24 AM
