car won't start good battey no power
Old Jun 4, 2007 | 05:06 PM
x5acob's Avatar
Default car won't start good battey no power
help! i changed the clutch in my 97 civic dx, i test drove it and i drove great there was nothing wrong. i parked it, it rained over night (idk if that made a difference) then in the morning i started it up, backed up then pulled forward, and then it just shut off. nothing works. the battery is fully charged, but theres no power to anything no lights no dinger, not even the dome light, turning the key does nothing. the bat. terminals are clean and tight. i can't find any blown fuses, the ones under the hood and the ones to the side of the pedels i checked all the wires i disconnected to do the clutch and every things good i can't figure it out. PLEASE HELP!!
Old Jun 5, 2007 | 04:40 AM
jd352's Avatar
Default RE: car won't start good battey no power
Maybe a ground wire got loose?
Old Jun 5, 2007 | 08:36 AM
riceburner700's Avatar
check to make sure you still have a ground wire on your trannsmission and from your valve cover to your chassis.
Old Jun 5, 2007 | 11:09 AM
WhiteCivic98's Avatar
Member
idk if you thought of it, but check and clean your battery terminals. I've had a similar problem and bought new terminals. Sometimes the battery terminals wont make the right contact (it happens to my car and it just wont start or nothin and i'll have to go under the hood loosen up the terminals and reposition them till i here the engine click). just my $0.02.
dkd
Nov 30, 2020 07:38 PM
David_S
Oct 24, 2013 10:06 AM
Aeon_Blue
Aug 3, 2010 05:40 AM
cderalow
May 4, 2007 10:26 PM
forrealb50
15
Nov 12, 2006 01:52 PM
