Car won't start, please help!
Old Nov 1, 2010 | 02:19 PM
ATGdrummer's Avatar
Default Car won't start, please help!
Last night I tried to start my 91 civic and nothing happened. Assuming the battery was dead I tried to jump it. Still nothing. So that led me to the next thing. The starter. Today I took it off and took it up to auto zone to get it tested and they said everything passed and it was in good working order. I replaced the ignition switch and still nothing. the starter doesnt even click when you turn the key. Any help is appreciated I really need to get this running again.
Old Nov 1, 2010 | 05:26 PM
Do the dash warning lights turn on when the key is in ON(II)? Do the headlights work? Does anything electrical work? If not, have the battery tested. Replace if it's dead.
Old Nov 1, 2010 | 05:36 PM
maachan513's Avatar
Main relay or main fuse???
Old Nov 1, 2010 | 07:26 PM
ATGdrummer's Avatar
Everything works except it doesn't click or turnover. I've been told to check the relays and fuses. I will tomorrow. Also will be replacing the battery cables. Kinda corroded. Where is the main relay located? In the engine compartment fuse box or in the car?
Old Nov 1, 2010 | 07:29 PM
Check whether the rubber stopper that presses on the safety starter switch is broken or has fallen out.
Old Nov 1, 2010 | 08:24 PM
ATGdrummer's Avatar
That's on the clutch correct?
Old Nov 1, 2010 | 08:25 PM
Yes, the top of the clutch pedal.
Old Nov 2, 2010 | 06:34 PM
ATGdrummer's Avatar
Thank you so much. (: She's running again. That diagram helped me tremendously.
DontHateOnEG8
20
Sep 6, 2008 06:49 AM
Civic Dx 349
Dec 10, 2007 07:09 PM
shadman52
Nov 28, 2007 05:25 PM
forrealb50
15
Nov 12, 2006 01:52 PM
eclecticanna
Dec 13, 2005 10:21 PM
