CD player wont turn off when key is removed!
Old Sep 19, 2012 | 04:19 AM
Angry CD player wont turn off when key is removed!
I've rarely had electrical problems with my car, but all of a sudden the CD player wont turn off! It started last night. I took the key out and the music didn't stop. When I pressed a couple of buttons on the CD player, there was a loud *thud* from all speakers at once. Sounded like a high voltage static pop. I ended up just pressing the power button to shut it off.
Otherwise, it seems to be functioning properly?
Any idea where to look for shorts other than directly behind the head unit?
Old Sep 19, 2012 | 09:07 AM
Could be the ignition switch. Does other stuff that should cut off with the key (wipers, turn signals, heater blower) stop when you turn the key off?
If its an aftermarket CD, the red wire should turn on and off with the key. If there's no voltage to the red wire yet it continues to play, the CD player is likely defective.
Old Sep 19, 2012 | 09:57 AM
Everything else does stop. Engine, wipers, blower. Inside lights pop on like normal. The only difference I can see is that the CD player doesn't turn off.
I'll check the red wire. It's aftermarket, and I've been running the same Alpine CD player since 2005.
Old Sep 19, 2012 | 03:08 PM
Hell Monkey's Avatar
We had the same issue a few years ago. Even with the key out the radio/clock were saying on. We ended up just pulling the fuse to them as we couldn't figure out any other way to get them off and didn't want the battery to die.
Old Sep 19, 2012 | 06:24 PM
conceptualpolymer's Avatar
That tells me that there may be a wire with worn/damaged insulation, allowing it to contact an always-live wire. I'd start there.
shadowfetus
Dec 13, 2012 08:46 PM
wearelove
Jul 22, 2012 05:31 AM
Phantom549
16
Jan 21, 2009 01:07 PM
Jgraham87
Aug 2, 2007 06:26 AM
b3651
Sep 24, 2005 09:46 PM
