check engine light 01 civic help!!!
Old Jun 18, 2010 | 02:09 PM
98whitecivic's Avatar
Default check engine light 01 civic help!!!
my friend has a 01 civic and it had a check engine light code was p0420 catalyst system efficiency below threshold bank 1 so i changed both o2 sensors and code was still there and plus a p1457 emission control system leak detected (control canister system) came after i changed both sensors. any clue? i dont think it is the cat i would think thats unlikely. any help would be good thanks
Old Jun 18, 2010 | 02:12 PM
P0420 = bad cat
p1457 - have you checked the gas cap seal?
Old Jun 18, 2010 | 02:50 PM
really how can a cat go bad you dont really need it
Old Jun 18, 2010 | 03:10 PM
SilverSedan's Avatar
Your cat eventually does go bad. It absorbs poisonous fumes and pollution. Eventually it cannot absorb any more and thus is not doing its job.
You do need it. it kills the air, contributes to greenhouse gasses, and (from what I understand) if you are caught without one you can receive a ticket for it - regardless if your state/province has sniffer tests or not.
Besides, between a proper high-flow cat and an ebay test-pipe... you gain a whole whopping 1hp. not worth it in my books
Old Jun 18, 2010 | 04:15 PM
You don't need the cat but your ECU does, otherwise it's going to turn the CEL on.
Old Jun 18, 2010 | 08:44 PM
dam so thats the cat thats the headers correct?
Old Jun 21, 2010 | 09:09 AM
so some one correct me if im wrong but thats the header cat?
Old Jun 21, 2010 | 02:46 PM
I'm not sure on the 2001 models, but I know that the 96-00 (I own a 97) the exhaust manifold and cat are one piece from factory. A non-honda branded replacement is 2 piece... exhaust manifold is one piece, and the cat is separate. They just bolt together and fit like a factory stock piece.
If you plan on doing the work yourself its not that difficult, esp if you have an oxy/acetylene touch handy. (I used one to slightly warm the nuts holding the old manifold on. I was scared of snapping a stud off)
Also, disconnect the battery and remove both O2 sensors before you start (make sure you know which one is upstream and which is downstream)
And once you're done putting it all back together, fire it up and let it idle for a good 10 minutes. This lets the computer re-learn what its like to have a full-working cat again
Rool_908
Jan 3, 2012 07:03 AM
mhlden
Oct 2, 2011 07:14 AM
towelie
Aug 30, 2010 05:08 PM
fastncrazy1
Jan 4, 2010 05:55 PM
Benny Sim
Jul 19, 2005 07:43 PM
