CIVIC 2005 Need help
Old Mar 4, 2007 | 03:06 AM
ifthy's Avatar
Default CIVIC 2005 Need help
My car broke last week within a week of changing oil, oil was leaking from oil filter. Oil was low and when I took it to the service center they found that the timing belt is broken and probebly valve may be bend. They insisting that its not due to oil leakage but b'coz of broken timing belt. Your kind advise will be much appreciated.
Thanks & regards, ifthy
Old Mar 5, 2007 | 12:50 AM
CiViC_NaTioN's Avatar
Default RE: CIVIC 2005 Need help
wow 05 civic and mechanical problem already ? ****t[:-]
how many K's on it?
isn't it covered under warranty?
Old Mar 5, 2007 | 12:52 AM
Belmont's Avatar
The car hasn't been in a wreck has it? It should still be under warranty.
Old Mar 5, 2007 | 01:10 AM
TheMoogly's Avatar
My warranty was expired within 2 years... I drove it alot...
Old Mar 5, 2007 | 08:46 AM
mill$civic's Avatar
Im not really sure what your asking. But how many k's do you have on your car? And you wouldnt be able to drive it if the timing belt broke, it sounds like youdrove it to the shop after this happend. If it was the timing belt, yes there could of been a valve bent.
Old Mar 5, 2007 | 11:43 AM
ya as mill$civic said....if its a valve bent or something then u r looking at something big, depending on what valve might have bented, u r talking $$$ ......I hope u didnt drive too much after the timming belt issue... but ya how many K's?
is it near or over 100k? 'cause if it is, then u r suppose to replace the timming belt
Old Mar 5, 2007 | 11:45 AM
My04Civic's Avatar
Administrator
god, it should def. be covered, i know mines covered for everything
hmm just realized u have 2 threads goin on the same time....
flipakajr
May 7, 2021 09:17 AM
loci
Nov 15, 2009 04:59 PM
ifthy
Mar 4, 2007 09:48 PM
Aslan817
Dec 28, 2006 04:05 AM
benchmade42
Oct 17, 2005 04:25 PM
