Mechanical Problems & Technical ChatIf you've got a problem you just can't figure out, a noise you can't diagnose, or a check engine light that won't go away, ask about it here!
Hello everyone, I was wondering if someone can help me with my issue, few days ago my a/c compressor stops working, looking in my fuse box fuse 1 was melted, I clean that check voltage and put a new fuse. However, the a/c compressor still not working I do all the test if bring voltage to the compressor relay and they engage and works perfectly. When I press the ac bottom, both fans came in, and the blower also works, I test the pressure valve and bypassing it, now, I know that the issue came with the positive that need to activate the relay to activate, I was following this wiring diagram.
Also, Idk if bypassing the relay we can test that the thermal protector is good or bad.
Thanks for the help
