'Clunking' Noise Worsening.....
Old Mar 21, 2009 | 05:40 PM
2ManyTickets's Avatar
Default 'Clunking' Noise Worsening.....
So I have had this 'clunking' noise on in the front passenger side when I go over bumps. It has been getting worse and I thought it was the blown strut. I've been planning on getting new suspension anyways, so I did and I thought it would fix it..but it didn't. I've looked at everything I think it can be.. and even took the suspension off and put it back on. Put a bunch of new bushings on etc.. Put it up on a lift.. and NO ONE knows what it is.......
help!!!!!
Old Mar 21, 2009 | 05:56 PM
mundy5's Avatar
could it be motor mount going bad?
Old Mar 21, 2009 | 07:00 PM
Have you checked for loose upper and lower ball joints or a bad CV joint in the axle?
Old Mar 22, 2009 | 03:12 AM
Well I dont think its the CV joint because it has nothing to do w/ speed..... doesn't matter if i'm going fast or slow its always the same when i hit bumps. It doesn't matter if i turn the wheel either direction either.... so i dont know if its that...but i'll check for the other things...
Old Mar 22, 2009 | 03:14 AM
Do you think it could be the halfshaft? or no... its wierd....has no correlation with speed
Old Apr 24, 2009 | 06:19 PM
Dexters96's Avatar
I may be having the same problem. I just purchased my car and I love it but I have noticed a slight clunking noise when I hit a bump and every once in a while when I shift. I have been driving a truck for awhile so my noise may be normal. I was told that the car had coil overs installed but I have not looked yet. Any ideas on what to look for would be great.
Old Apr 25, 2009 | 11:24 AM
danomatic93's Avatar
June 2010 ROTM
Possible solution...
Check that all your suspension bolts are torqued to specifications. Since my suspension is really tight I have had some bolt loosen a little. Especially check the bolts on the front subframe.
MXandSXracer21
Aug 11, 2012 09:53 AM
dsilentninja
Apr 2, 2009 05:50 AM
Phalcon
Nov 21, 2007 02:49 PM
Chandlergreg
Aug 1, 2007 03:31 PM
powderdude
May 11, 2005 03:49 PM
