Cluster help...
Old Sep 29, 2007 | 03:02 PM
Bodei24's Avatar
Default Cluster help...
Hey, yea i recently installed the white layout for my gauge cluster, to do so i had to remover the needles, when i did, all but the rmp workedk, the rpm gauge is slow, sluggish, delayed sort of, is it because its just not sticking? can i try spraying some hair spray or glue spray, to halep make it stick? and also a few days later my speedometer just stopped , i didnt take it a part to see if its just stuck... i really dont want a new cluster any ideas to fix these problems will be appreacated, thanks
Old Sep 29, 2007 | 04:13 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: Cluster help...
wow, ummm, you weren't supposed to remove the needles... ...I don't know a how-to ways to fix them, it's a make a guess kind of a fix. You'll probably have to get new gauges if you want them to be acurate. Call some auto shops and see if they know can calibrate them for you.
Old Sep 29, 2007 | 04:55 PM
Bodei24's Avatar
crap...then whats the right way to get the white layout on?
Old Sep 29, 2007 | 11:17 PM
June 2010 ROTM
just slide the layout on with the needles on, you have to go at an angle.
Old Sep 30, 2007 | 10:53 PM
Basil's Avatar
well, you are NEVER supposed to remove those needles, they are in exactly the place they are supposed to be, and are very difficult to replace correctly... you might need a new cluster, or at least a tach. sorry bro
apexi_89
Sep 5, 2006 01:26 PM
twax121
Aug 21, 2006 11:00 PM
mentaldis0rder
Jul 29, 2006 10:40 PM
1998wagonhatch
Aug 15, 2005 03:36 PM
millertime17
Jun 26, 2005 09:38 PM
