Clutch not building pressure
I recently bought a 2005 Civic DX coupe from a friend of mine. I knew going into it that the car needed some TLC. When I popped the hood I immediately noticed that the clutch reservoir was missing the cap and that there was a layer of white silt sitting on top of the fluid and that the fluid itself was as dark as coffee. I went ahead and bled the system but after the bleed the clutch was not building pressure and the pedal was all the way down on the floor. After some research, I replaced BOTH master and slave cylinders and again bled the line. Still no pressure, so I replaced the line with the same result. Mechanically there is nothing wrong with the clutch as my friend was able to drive the car before I bled out the fouled up fluid. I am curious to see what y'all think could be going on. Could there still be air pockets in the line that I just gotta keep trying to bleed out? I've had a helper help me bleed the line and even used our shop's vacuum bleeder. I would appreciate any advice y'all have. -- Akodo
kevin_405
Nov 2, 2010 05:54 PM
okotokssteve
Apr 16, 2010 06:07 AM
blatin
Oct 16, 2009 05:52 PM
ic892003
31
Feb 8, 2008 04:46 AM
