Mechanical Problems & Technical ChatIf you've got a problem you just can't figure out, a noise you can't diagnose, or a check engine light that won't go away, ask about it here!
fluid things like that always make a fluid noise. It's normal, but when it makes that noise it is the fluid compressing and being shoved through a tight space like around a corner in a tube.
