clutch squeak
Old Jul 11, 2007 | 03:50 AM
Rklamb16's Avatar
Default clutch squeak
when i press my clutch in, it makes a quick squeak... is there a way to fix this?
Old Jul 11, 2007 | 06:53 AM
Default RE: clutch squeak
Is the squeak from under the hood or under the dash in the clutch pedal area? Do you have a hydraulic clutch system ('92 and later models) or a cable?
Squeaking from inside the clutch housing on the transmission means you'd have to pull the transmission out to fix it, but if it's one of the linkage pivot points that you can reach, just apply oil or grease.
Old Jul 11, 2007 | 12:16 PM
1997civic's Avatar
yeah i got that on my accord, and now my civic, i have written it off as typical honda noise...does not sound bad to me, just a squeaky spring
Old Jul 11, 2007 | 01:35 PM
dfdon's Avatar
its prolly your throwout bearing
Old Jul 11, 2007 | 03:21 PM
Rklamb16's Avatar
is the bearing expensive to replace or fix?
Old Jul 11, 2007 | 04:24 PM
When it's the throwout bearing it'll only squeak with the engine running. Most people do a complete clutch job when the throwout bearing is bad because you have to take the transmission out of the car anyway.
Old Jul 12, 2007 | 08:00 AM
1997civic's Avatar
ok now i am currious as to what it is on my civic...before thought no big deal an still think it is nothing to worry about, but even if my car is sitting no engine running if you push the clutch in, a small squeak can be heard, but not all the time. it comes from somewere between the tranny and the pedal but outside. it sounds like a spring on a bed that squeaks.i have no problem because my car is loud so noone can hear it, but better to find out what it is
Old Jul 12, 2007 | 08:10 AM
Rklamb16's Avatar
my clutch still squeaks with the engine off, so it must be something simple then, right?
Old Jul 12, 2007 | 11:09 AM
Have someone press the pedal (engine off) while you listen under the hood and locate it exactly. It could be the pivot where the rod from the slave cylinder presses on the lever that goes into the housing. This is under a rubber boot on the housing.
nealkal
Apr 27, 2010 02:43 PM
Lewy2k
Jul 14, 2009 05:45 AM
dooka4u4
Jun 6, 2005 10:18 PM
kjreinha
May 27, 2005 05:24 PM
Frankyoz5711
Sep 3, 2004 07:33 PM
