clutch trouble
Old Sep 24, 2006 | 12:26 PM
rickm's Avatar
Default clutch trouble
I just bought a 92 civic DX and the clutch is slipping so I want to adjust the clutch however I can't find the clutch cable under the hood. Can anyone help me with its location?
Old Sep 24, 2006 | 12:59 PM
fglaustin's Avatar
Default RE: clutch trouble
if like my '88, it is to the right of the battery tray.
have to take the battery out, or be down on the ground and look up at access it.
and if like mine, should jack up the front wheels so that they are off the ground.
<edit>
this is the location of the clutch cable adjusting ****
Old Sep 24, 2006 | 03:04 PM
rickm's Avatar
fglaustin: Thanks.
If that was a picture you included it didn't show up. I think now that mine may be hydraulic.
Old Sep 24, 2006 | 07:48 PM
fglaustin's Avatar
Oops. sorry bout that.
i was speaking about a cable clutch.
not much experience with hydralic clutches.
have to pass.
Old Sep 24, 2006 | 09:22 PM
HARI.'s Avatar
yours is a hydraulic transmission so you don't have a cable to adjust your clutch. did you check the fluid level? could also be that it is time for a new clutch
Old Sep 24, 2006 | 09:55 PM
fglaustin's Avatar
i think there is a pedal adjustment (perhaps someone has the specs ?)
Old Sep 24, 2006 | 10:16 PM
fglaustin's Avatar
no - not a picture.
Old Sep 25, 2006 | 01:54 PM
rickm's Avatar
The fluid was low so I added some. The parts guy "guaranteed" me that it was the slave cylinder so I put a new one on...same slipping and shuddering.
About how much does it cost to have a new clutch installed?
Old Sep 25, 2006 | 11:31 PM
HARI.'s Avatar
ORIGINAL: rickm
did you try bleeding your clutch line when you added fluid? you might also have air in the line. it will cost about $250-$350 to install new clutch. it's better if you do it yourself
Old Sep 26, 2006 | 01:55 AM
deserthonda's Avatar
if it slips it is NOT a low fluid issue ...low or no fluiod would make it hard to get in to gear,, if clutch slips , it is time to replace the clutch or the clutch master cylinder rod is adjusted too long ( not likely )
