cluth problem
Old Sep 23, 2007 | 02:00 PM
carter's Avatar
Default cluth problem
clutch sometimes get stuck and wont let me shift until i phisically move it back up i check the fluids and it was out so i put some some in where it goes and now it wont come stay up at all what can i do oh yeah when i put in the brake fluid it turned black like if it was dirty can someone please help thank you.
[/align]
Old Sep 24, 2007 | 05:13 AM
Default RE: cluth problem
The fluid must be leaking out. Pull back the boot on the push rod on the slave cylinder and check for fluid leaking out there. If there isn't any on the slave cylinder, look under the dash at where the rod goes into the master cylinder, a master cylinder leak will have fluid running down from there. Replace the leaky part and bleed the system. You can get rid of the black fluid by flushing new fluid thru the system as you bleed it.
Old Sep 24, 2007 | 06:06 AM
dito... reason it still wont work is cause ya got abunch of air in the line... bleed it just like ya would your brakes... check for any leaks and fix them if ya find them....
Old Sep 24, 2007 | 06:52 AM
carter's Avatar
thanks alot thats what i am going to do by anychance you wouldnt happen to have a obd1 gsr ecu.
[/align]
zookre
Jun 6, 2014 06:22 PM
flipsk8er0312
Jun 22, 2008 07:58 AM
tanksOnFire
Jan 8, 2005 03:38 PM
tanksOnFire
jwsimons
Jan 4, 2005 10:02 AM
