complicated ECU wiring question
Old Sep 3, 2012 | 06:29 AM
tuboflard's Avatar
Default complicated ECU wiring question
OK so mechanically if an engine is good all it needs to run is the wires that come from the ecu and go to the engine bay, right? I mean there is lots of other wires that go to stuff like head lights and tail lights but in theory if you unhook everything except the wires that go directly from the ecu to the engine and then crank the car it will start right? also i don't think there is a wire to the fuel pump but you could just run a switch with relay.
basically all a car needs is switches and a ecu to run. no main relay or other random wires.
trustdestruction
Jan 29, 2009 12:02 PM
Shbek
Nov 28, 2007 08:04 AM
1meanb18
Aug 23, 2006 01:43 AM
stylincompact
Jul 11, 2006 10:35 AM
bain0005
Jul 6, 2005 03:51 PM
