HondaCivicForum.com
-   -   Compression check.... (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/compression-check-91806/)
HiDesertRat Jan 3, 2012 04:23 PM
What is a good reading for a compression test on a D16Y8 engine? I let mine crank about five or six tmes and then took the reading. All the clyniders read around 150 psi. I think this is good, but woud like to know for sure.
I had to run the checks because I was concerned about the engine power. Right now, if I put the front tires at the bottom of a set of car ramps, the car will not pull itself up the ramps. I have to get a three foot run at the ramps, in order to get it up on them.
There is a possiblity the transmission isn't shifting into low gear, but that is yet to be determined.
briceman124 Jan 4, 2012 07:12 AM
not really answering your question but how do you do a compression test on a honda civic?
