COOLANT LEAK
Old Jun 4, 2007 | 03:31 PM
CHUCKLZ98's Avatar
Default COOLANT LEAK
Hey everyone, I have a stock 98 EX (150k)with a coolant leak. I can't see anything leaking while it is running. When I turn it off and let it sit, there will be a tiny puddle just under the left side of the engine. I can't see any coolant leaking from any hoses, or on the top anywhere. I had the water pump replaced at 90k. Can I just remove the upper timing cover to inspect the water pump?When a water pump goes bad where does the weephole drop the coolant? How many coolant lines run underneath the engine?
Old Jun 4, 2007 | 04:15 PM
dfdon's Avatar
Default RE: COOLANT LEAK
water pump would leak from the pump...which it sounds like its not...i had the same problem check the line going into your intake mani or ur thermostate
Old Jun 4, 2007 | 04:42 PM
CHUCKLZ98's Avatar
Thanks for the info, I'll check those places. If my water pump was bad, how would I know, since it is concealed by the timing cover?
paak
14
Nov 19, 2011 02:24 PM
jamned
Nov 30, 2007 06:48 AM
SpeedRacer_87
Jul 25, 2007 06:51 PM
honda_farmboy
Jul 2, 2007 07:36 AM
Sygnus
Nov 12, 2005 09:48 PM
