crank pulley bolt removal
Old Jun 17, 2012 | 07:14 AM
me262dave's Avatar
Default crank pulley bolt removal
I have a 90 civic that I can't get the pulley bolt off of. The factory manual calls it
a "special" bolt, but doesn't say why. Is it left handed thread?
It also says to turn the engine counter clock wise to set top dead center, and if the
bolt comes loose to re torque. So I assume that it is normal threads.
And it is an automatic so the engine keeps turning over, no way to get good
action on the bolt.
Thanks
Dave
Old Jun 17, 2012 | 09:24 AM
zerojett's Avatar
put it in gear and wedge a pry bar between the wheel studs and the floor. it can take a lot of force to remove it. normal threads, don't lose the little metal pin.
Old Jun 17, 2012 | 09:28 AM
It's right hand thread. The best way is to use an impact wrench. The engine will not spin because of inertia.
Turning the bolt by hand (with a long lever), the engine will turn. On an automatic you can try to stop the engine from turning by removing the starter and jamming the flywheel. Some crank pulleys have a hexagonal recess that accepts a special pulley holder tool.
Old Jun 18, 2012 | 10:14 PM
f22_strike's Avatar
I've always got them off by putting it in 5 th with the wheels on the ground makes the engine harder to turn
Karrde
12
Jan 24, 2009 05:09 AM
oldmoline
Oct 17, 2007 03:51 AM
truckmsl
Aug 13, 2007 08:51 PM
steelnutkss
Feb 8, 2007 08:37 PM
ray90813
Jan 10, 2006 05:44 PM
