Cruise control?? Whine noise?
Old Nov 12, 2012 | 07:23 AM
schmitt's Avatar
Default Cruise control?? Whine noise?
97 civic lx
When setting cruise it will very itself 5 to 8 mph different from what i set it at. Also you can deceal and after a minute or two you are going just as fast again. Takes awhile for it to kick in too.
Any help would be great.
Also have a whine nose going down the hwy at times. I can push in the clutch and it will go away.
Old Nov 12, 2012 | 09:38 AM
schmitt's Avatar
no one? does anyone know where i can go to ask these questions otherwise?
Old Nov 13, 2012 | 05:01 AM
The noise may be from inside the transmission. Make sure the fluid is full (checked by unscrewing the plug with the 17mm head on the right side near the axle). If you hear significant noise idling in neutral which goes away when you press the clutch in, the input shaft bearings are bad. This is very common.
Old Nov 13, 2012 | 05:54 AM
schmitt's Avatar
no noise at idle just hwy speeds.
dmsteele92831
Jul 23, 2007 11:10 AM
snosurfa7
Mar 25, 2007 05:50 PM
wantacivicwagon
Oct 24, 2006 01:21 PM
tonyeight
May 25, 2005 01:57 PM
polo708
Oct 8, 2004 10:58 AM
