D16A?? found one, but i need some help
okay fellas, im still pretty new to Honda's in general, so i need some help. i've searched the forums and found a lot of good info, but my question is this.
i recently found a project car not finished w/ a D16A DOHC engine in it, or in the back of the car. the motor actually looks great, but it looks like an unfinished project. i can get the motor for super cheap, and whatever part i can find lying around but, but my concern is that there's no trans. can i use any D-series trans w/ this motor? what wiring will i need, and what ecu do i need to run.
i have a 92 EG hatchback CX. its my work car right now, and im tired of the oil burning/no power motor it has right now. what will i need to swap this baby in there?
btw, the motor and extras are only going to cost me 100-130 bucks. its it worth it? thanks in advance guys!
most D16A engines are DOHC
most are edm or jdm as well (meaning europe, australia only)
all of them are 110-130hp/99-110tq
used 1986-1996
in short, to swap, depending on age and origin of engine, you might have a lot to do.. or you might have very little to do
your engine is likely a D15B series motor, so you'll definitely have some fun converting to connect to an old ODB-0 car from your ODB-1 car
used 1986-1996
^^thanks for the reply! i kind figured that i'd have to convert from OBD1 to OBD0. no thanks on that. i found the engine in the back of an EF, pretty much ready to go, but for an EF swap.
i found a D16Y7, which is more then likely a better swap.
a dual cam d16 is from an old first gen integra, i don't really believe thos are capatable swaps. your best bet since you have a 92 which is obd1 is to get a JDM d15b vtec or a d16z6 vtec, tha way you are adding power and vtec, instead of an extra cam that doesn't give you any more power.
as i understand, the Y7 doesn't have V-tec? i have a Y8 head available, and a del sol Si intake mani w/ Y8 injectors and ecu. im pretty sure i'll need the Y8 harness too right?
now that would be considered a mini-me swap right? would i have to use the Y8 head gasket, etc.? also, i found a 95 ex 5spd trans w/ axles. im considering getting that too because the stock gearing in my CX stinks bad.
i appreciate the help alot guys! im so use to MR2's that this is a new area i have yet to explore. its a hell of a lot easier too.
