D16Y problem
Old Aug 3, 2005 | 06:49 AM
ooohyeah's Avatar
Default D16Y problem
can anyone help with an issue i'm havin?? my civic has recently started 2 develop a surging issue. it only happens wen cold or under heavy load,e.g. uphill. ive quickly checked the leads and plugs, nothin. it feels like an electrical problem, but i'm stuck. i dont think load should make a difference. overall, shes in good health. any ideas??
Old Aug 3, 2005 | 11:08 AM
vdog's Avatar
Default RE: D16Y problem
Sounds like the problem I had, my car would idle up and down when it was hot or cold, in traffic etc, etc. I replaced my Idle Control Valve. That might be your problem.
Old Aug 3, 2005 | 11:14 AM
ooohyeah's Avatar
just 2 let all no, no idling issues. idles, runs, starts fine. blows fuel smoke, uses small amount of oil, nuthin 2 worry bout tho. dunno wats dun 2 the motor. only got invoices and dyno sheets wen i bought it. 105kw at the wheels. does alright against a worked 1.8 mazda bpt tho. any ideas??
Old Aug 3, 2005 | 03:30 PM
Remmy's Avatar
i still dont really understand the problem... could you explain the symptoms?
Old Aug 3, 2005 | 03:52 PM
Street Sniper's Avatar
What year is it? It sounds like a lack of fuel; fuel filter, tired pump, clogged injectors.
Old Aug 3, 2005 | 08:12 PM
ooohyeah's Avatar
could be fuel, y only wen cold or under load?? symptoms are, under acceleration, the motor seems to surge ie: u can feel the power drop off, even only momentarily. it never stalls or slows considerately, just enuf 2 annoy me!! its not at once eitha, it goes for the entire time the motor is under load, until u hit the top of the hill. on the flat, back 2 normal! sorry guys, i dunno how else 2 explain it
Old Aug 3, 2005 | 09:29 PM
Remmy's Avatar
hmmm... dirty injectors are the only thing I can say about it. It will only cost you $5-10 bucks but when you go to get gas, pick up some injector/ de-carbonizer. Its worth a shot.
Old Nov 21, 2005 | 10:30 AM
da1andonlydjr's Avatar
have u checked your MAP sensor operation?
Old Nov 21, 2005 | 10:48 AM
vdog's Avatar
The reason I changed my Idle Control Valve was because my car was surging up and down. At stops and while moving, its not just to control idle speed.
Idrivenaked
Mar 31, 2011 04:41 AM
illinoisboy
Mar 29, 2011 08:51 PM
madjoker14
Dec 15, 2008 11:16 AM
**Alan**
Dec 28, 2006 03:18 PM
XCM828
Oct 6, 2006 09:48 PM
