Dash Cluster and Climate Control lights takes a minute to turn ON after headlights!
Old Oct 31, 2008 | 11:48 AM
tylerjamesbush's Avatar
92 Civic LX
What do you mean? How do i ground the dimmer connector? I have to admit i'm a Video Production and Computer guy not a car guy, but willing to try to fix it.
Old Oct 31, 2008 | 11:53 AM
Originally Posted by tylerjamesbush
92 Civic LX
For reference, see post #2 in this thread. Remove the dimmer switch, insert an exposed end of a wire into the red wire terminal of the dimmer connector, attach the other exposed end of the same wire to the metallic frame under the dash, and then turn the headlights switch ON one click. Do the dash lights now turn ON full bright?
Old Oct 31, 2008 | 12:09 PM
Can you go into more detail how to ground the red wire, I'm a Computer guy not a car guy, but i'm learning.
Old Oct 31, 2008 | 12:11 PM
I described the procedure in the previous post. Let me know if it is still unclear.
Old Oct 31, 2008 | 12:13 PM
If the tail lights aren't on, there is no hope of the dash lights working. You should check for voltage from terminal "D" of the switch to ground with:
*everything plugged in and
*the switch on the first or second click,
*but during the time the lights are not on.
If you have battery voltage, the switch is OK and there's likely a problem in the fuse box or somewhere else in the wiring under the dash. If you have no voltage, the switch could be bad or the plug has a bad connection to the switch terminal.
Edit: Use terminal D, not E. E should have power all the time from the battery.
Old Oct 31, 2008 | 12:22 PM
Clarification for OP. mk's voltage tests are done with the wire harness connector attached to the combination switch, whereas my continuity tests are done with the removed combination switch itself. Both tests should be informative. I am unsure, however, how you would do mk's voltage tests with the switch and connector connected.
Old Oct 31, 2008 | 12:59 PM
I think it is one of those big plastic connectors you can see the metal pin sockets through the back and touch them with a probe. Or push your meter probe through the wire insulation and touch the copper inside. Since it's inside the car you don't have to worry about water getting into the hole.
Old Oct 31, 2008 | 01:05 PM
I removed the Stereo, I have a red and black wire with a cap and a white and blue with a cap in with the stereo wireing area. both seem to be just an end not attached to anything. It is not the factory stereo. The Stereo works fine.
Old Oct 31, 2008 | 01:11 PM
The Red/Blk wire powers the radio light and is part of the fuse 19 circuit. As long as it is capped off, then there should be no problem.
Old Oct 31, 2008 | 01:14 PM
OK Progress, When i did wire in the red scocket and grounded it i have dash lights. So is it the dimmer switch?
