did i blow my head gasket?
Old Nov 2, 2008 | 11:04 PM
Gallo 24's Avatar
Default did i blow my head gasket?
so my civic started backfiring alot when i downshifted one day and continued to do so when i downshifted. it has a catback so it seriously sounded like firecrackers in my exhaust so i decided to change my sparkplugs and one of the plug wires was fused/melted with the spark plug, after about a good 2 days of pulling/pb blaster/hacking at it with a chisel i broke apart the plug from the wire in bits and replaced the plugs and wires after making sure everything was clean. drove it for a bit and the car started to loose power felt like it was running out of gas but maintained speed for a bit before totally dying and the temp gauge was maxed out. i had no clue what was wrong with it so i took it down to a garage and told them to look at it and tell me whats wrong and get a call from them telling me they changed the plugs and wires and it runs fine now... i was thinking in my head wtf... ended up charging me 250 for the exact same thing i did cept i did it for 40 bucks, drove about a mile up the street and the temp gauge was maxed out again and in fear of damaging things more than they already were i returned it telling them its overheating and they didnt fix **** but im leaning toward the headgasket but im not sure.
Old Nov 2, 2008 | 11:12 PM
Take off the radiator cap.
Does it look like oil is mixed in your antifreeze? If so, the headgasket is most likely the culprit.
I doubt it's the headgasket. It could be a number of different things. First of all, get your $250 back. About the backfiring: have your ignition timing checked.
Have your thermostat checked. I'm thinking your thermostat is probably stuck closed.
slade8
Dec 6, 2009 06:23 PM
Crispy1
Apr 11, 2009 08:44 AM
95lsvtec
Feb 14, 2006 11:46 PM
civicpimpinsc
Feb 1, 2006 10:36 AM
civicpimpinsc
Jan 7, 2006 07:58 PM
