Disabling 09 Civic Si Daytime Running Lights?
Old Apr 10, 2009 | 05:47 AM
Clyburn13's Avatar
Default Disabling 09 Civic Si Daytime Running Lights?
I searched the forums and couldn't find anything for the 09's with this question. So does anybody if you can/how to disable the DRLs?
Old Apr 10, 2009 | 05:55 AM
I don't have the 09 Civic fuse box diagram, but typically the DRL can be disabled by removing one of the DRL fuses under the hood or dash. When you identify that specific fuse, would you please post the information in this thread so that others may benefit.
Old Apr 10, 2009 | 06:02 AM
Clyburn13's Avatar
Sure!!!! Make the new guy the Guinea Pig!!!!!!!!!!
just kidding...i'll see what I can come up with and then post it.
Old Apr 10, 2009 | 06:06 AM
Haha. Removing a fuse will almost certainly be the solution. There should be fuse diagrams on the covers for the dash and hood fuse box. The fuse should be labeled DRL. There may be more than one. Try each one at a time.
Old Apr 14, 2009 | 06:36 AM
Clyburn13's Avatar
http://www.lightsout.org/disable.html#Honda
"2006+ Honda Civic. Confirmed on 2009 Civic Si as well. Simply remove fuse #37 (7.5A) from the INTERIOR fuse box (under the far left side of the dash). Goodbye DRLs. Absolutely NO after-effects (i.e. - idiot lights, etc.). Clean and simple!"
This came from the "Association of Drivers Against Daytime Running Lights" web page (link above)
Old Apr 14, 2009 | 08:59 AM
Clyburn13's Avatar
Works as advertised. Just did it and checked all light functions and everything is in working order.
Brian
16
Dec 25, 2021 03:12 PM
bpcorliss
Aug 15, 2008 10:10 AM
apexer
Apr 8, 2006 03:02 PM
apexer
Mar 14, 2006 12:03 PM
AdamC
Jun 2, 2004 04:10 PM
