Distributor Assembly
Old Apr 27, 2009 | 10:13 AM
97Sedan's Avatar
Default Distributor Assembly
Earlier today I had the CEL come on, I took over to the local autozone and had them pull the code P1361, TDC sensor. No problem, so I go to my trusty website, hondacivicforum.com and put in the code number, the general recommendation is to replace the distributor assembly because the TDC sensor is kind of built in. But I have a question about the word "assembly" when the assembly needs to be replaced, that means everything inside the distributor also?
Thanks in advance.
Specs: 97 DX Sedan
Manual 5-spd
D16Y7
Old Apr 27, 2009 | 11:09 AM
You need the distributor housing. You can use the coil, ICM, rotor, cap, etc. from your old distributor if they are fine.
Old Apr 27, 2009 | 01:35 PM
97Sedan's Avatar
Thanks for the help RonJon, what can I expect to pay for the "Distributor Ignition Assembly?" The Honda dealership says $316, is there any cheaper anywhere else.
Old Apr 27, 2009 | 01:46 PM
Honda OEM:
At Majestic Honda, you can buy the ENTIRE distributor for ~$280 (total).
Or you can buy the distributor housing + ICM + O-ring for ~$244 (total).
Old Apr 27, 2009 | 02:04 PM
97Sedan's Avatar
Is it possible to tell what brand of distributor is on the car without taking it off? I would rather not take the distributor apart considering this car is my daily driver and it is storming outside.
Old Apr 27, 2009 | 02:17 PM
I have the same Civic. It has the TEC distributor -- the one shown in the diagram at the Majestic link.
Jacks97HB
Jan 19, 2006 07:17 PM
dcompton
Oct 5, 2005 05:17 PM
mmille_mr2
May 26, 2005 05:15 PM
Hector
Mar 10, 2005 08:50 AM
Silver7
Sep 21, 2004 05:43 PM
