Enginer rough when weather is cold and wet
Old Dec 15, 2008 | 08:45 PM
jbum's Avatar
Default Enginer rough when weather is cold and wet
Hi everyone,
I just had a quick question. I have a '93 DX Sedan with 171K miles on it. The engine is great and I get 44mpg (albeit I drive 60+mph on the freeway) and I don't have any problems with it.
Just a minor thing I noticed today was that the engine started and sounded like there was some moisture inside. You know that kind of puffing noise... again, it was very minor and it went away in a few seconds. The weather was extremely cold and it had been raining and I have seen this kind of behavior in my '89 Integra before (only when it's cold and wet).
I'm sure since this is an old car, the clearance on the engine parts isn't as tight as it used to be. I just wanted to see what other people thought and would love to know what common parts wear out and cause this symptom?
I'd like to refresh any component that may need replacing but I'd like to have a better idea what those may be.
Thanks!
jbum
Old Dec 16, 2008 | 04:33 AM
Misfire in wet weather is often caused by bad plug wires.
Old Apr 27, 2009 | 09:35 AM
jbum's Avatar
Another question very much related to this...
When conditions are cold (and possibly damp/wet), the engine sounds harsher and raspier. On warm days, the engine sounds muffled and smooth, as if things are tight as they should be. I don't think it's just in my head.
When cold, the car sounds like it's a '93 model with 180K miles on it. On warm days, it sounds smooth and it's in great condition. Just to be clear, it doesn't sound like the car is broken down or anything. Just raspy and noisy.
Old Apr 27, 2009 | 09:47 AM
Is the difference in how the engine itself runs or an indication that something is rattling or loose in cold weather? More detailed information would help.
Old Apr 27, 2009 | 10:45 AM
jbum's Avatar
I think the sound makes me think the engine runs better when it's smoother sounding but I'm pretty sure there is no difference.
When I'm driving on the freeway (5th gear), there is no real difference in sound either. It's in 1/2/3 gears where I feel the sound is raspier... maybe until it fully warms up. Maybe things like insulation, etc. all expand and help muffle the sound when warm/hot. Just a guess.
There is no rattling... just a harsher engine noise.
Old Apr 27, 2009 | 01:22 PM
When did you last replace the plugs, wires, cap, and rotor? Start by inspecting them. Have you checked the ignition timing with a timing gun?
Have you cleaned the FITV and IACV? See links in my signature.
Have you tried a Seafoam treatment? See forum DIY section for details.
Old Apr 27, 2009 | 02:07 PM
jbum's Avatar
All good suggestions, thanks,
I just replaced the plugs. Cap/rotor I replaced 15k miles ago. Wires were good when I checked them during the plugs replacement (by measuring the resistance from end to end). The wires were clean too.
I checked the timing maybe 30k miles back so I'll check it out again. I'll check out the fitv/iacv.
Is there a better way for a engine cleaning than seafoam? it sounds messy for the environment... sorry i'm partial to my environment.
Thanks!
Old Apr 27, 2009 | 02:24 PM
Unfortunately, cleaning the FITV and IACV (or injectors and IM with Seafoam) involves the use of organic solvents. You could consider just replacing the parts with new ones, but this will be much more expensive and possibly no better for the environment. You're stuck between a rock and a hard place. I think cleaning old parts is the best option all the way around.
MaximusFunk
Mar 13, 2012 08:26 PM
bwburbank
Jan 23, 2012 03:53 AM
Stumasters
Jan 20, 2008 12:58 PM
Dups
Feb 27, 2006 07:00 AM
RaskyR1
Feb 21, 2006 02:38 PM
