Do i need a new clutch?
Old Nov 25, 2006 | 06:37 PM
burnindesirez02's Avatar
Default Do i need a new clutch?
How do you know when you clutch goes out. My clutch doesn't have any pressure on it anymore and when i try to shift it is hard to. How much would it cost to get it fixed or is it easy to fix?
Old Nov 25, 2006 | 07:01 PM
Misha's Avatar
Default RE: Do i need a new clutch?
If it is hard to shift, it is not clutch, it is cable or hydraulic, whatever your car has. If it's cable, you need to adjust it, if it's hydro - bleed. This could be shifter linkage, too.
Old Nov 25, 2006 | 07:03 PM
Fiirkan's Avatar
Yeah if it was your clutch your would know it, cause when you try to shift it would grind.... and you know when it grinds
is that cheaper than a clutch? cuz my car doesn't want to go into any of the gears and the clutch has no pressure on it. so its either the linkage or the cable.
Old Nov 25, 2006 | 07:05 PM
is the cable easy to adjust?
Old Nov 25, 2006 | 07:07 PM
Misha's Avatar
ORIGINAL: burnindesirez02
If your clutch pedal does not push back, most probably your cable is dead - you need to replace it, not adjust. It's not that big of a job and can be done at home with minimal mechanical skills
Old Nov 25, 2006 | 07:08 PM
what do you mean not push back? When i push it..i don't have to use any effort but it come backs up by itself.
Old Nov 25, 2006 | 07:10 PM
Misha's Avatar
ORIGINAL: Fiirkan
That's when your clutch spring is gone...
Old Nov 25, 2006 | 07:11 PM
Misha's Avatar
And you don't feel resistance that you usualy fill. That's what I mean
Old Nov 25, 2006 | 07:14 PM
so i need a new spring and clutch cable
