Do I really NEED a knock sensor?
I replaced mine 5 months ago. I reached in to check and make sure it was still plugged in because I'm getting the code for it. I barely touched it and the plastic part came off the metal part. There's still a little wire running to the sensor, but I figure it's probably no good or at least setting off the CEL. So, do I really need it? Everybody talks about grounding the wire to get the CEL off. Is that a good idea?? I'm sick of looking at that light. I just replaced a missing bulb for it, but I'm ready to pull it back out!
just ground it. the oem knock sensor really aren't that accurate in the first place. and imo it's much worse to take out the bulb in case some other problem occurs and the check engine light needs to come on, if you ground the sensor with a wire, cel still function and the code goes away
they are pretty fragile and break frequently too, which is why i have mine grounded
I was only thinking of taking out the CEL bulb because what good does it do me if its on all the time? I still won't know if there's a new problem. Just put it in every now and then and check the codes. But I will try grounding the wire. Seems like he best solution.
