Does anyone have any ideas?
1 Attachment(s)
I have a 98 civic ex automatic, When i put it into park it surges up and down from 500 rpm to about 3000 rpm. When i put it into drive it idles still at about 1500 rpm and pulls forward. I wanted to try the iacv before i took it to a shop but i cant find it on my car. It is not on the back of the intake manifold does anyone know where it could be or any other ideas how to fix the problem thanks.....
Attachment 16946 |
It's on the bottom of the throttle body on an automatic. The plug comes out the back. I can't quite see it on your picture.
Make sure your throttle cable goes slack and the throttle plate closes completely when not pressing the gas pedal. Check all the vacuum lines and the connection between the throttle body and the manifold, and the manifold and the engine. Anything that lets extra air leak into the intake manifold will cause the idle speed to increase. |
also do you have a cel on ??
Yes it is but it came on months before it started acting up
I guess the best way to do that is to go by the auto store and have them hook up the computer to it right?
yea you can have them pull the codes or you can do it yourself.
http://www.honda-tech.com/showthread.php?t=1901557 |
Ok first of all the ABS light was flashing and not the cel light i dont know if thats right or not but anyway i got 61 POS but i had a custom exhaust put on so i think it didnt need that sensor anymore what do you think. Also 16 Fuel Injectors which i put some in 2 or 3 years ago. and 18 which there is no sensor for i counted it 4 times so its 18 idk. my speedomitor is not working which is 17 but i got 18. So what do you think 61, 18, 16 thanks!!!! for the help
The high idle is probably not a sensor or ECU problem, it's an air leak issue.
Whenever you have multiple codes, make a note of the numbers, then reset them and see which ones reoccur. Some of the codes may be from old problems that were transient in nature and have resolved themselves. You need to eventually get everything working so the CEL stays out in order to have full performance. More detailed codes are available by using an OBDII scanner instead of the jumper wire and blinking light method. But again I don't think the codes are going to tell you much about the idle problem. |
Ok so how do I go about finding an air leak I have no ideas thanks. And it only does it 3 or 4 days a week or if I let it sit all weekend its good til tues or wed. If it was an air leak wouldn't be constant I don't mean to second guess u im just tring to get help thanks a lot!
