Down stream 02 sensor
Old Jul 12, 2010 | 09:13 AM
Glenn22's Avatar
Default Down stream 02 sensor
I need to wire in a down stream o2 sensor into my 2002 civc ex engine wire harness becuase i have a dx cabin harness which doesnt have a downstream 02 conector on like the ex would have.
01-03 electrical diagram: http://www.clubcivicquebec.com/HowTo...iagramsEM2.pdf
I would like to wire it into the harness much like the dx/lx engine harness if possible. I have two questions:
1. There are two areas in a civic ecu for the downsteam o2 sensor heater ground and the senors signal wire ( in the E connector(page 15 of diagram) which i believe is only for the ex and in the A connector (page 13) which i believe is only for the dx/lx). My question is are the dx/lx secondary o2 sensor pin outs on an civic ex ecu available to be used or do i need to use the E connector pinouts? i know the answer is seems obvious but i just want to be sure if the E connector is my only option or not.
2. My second question is in reguards to the power source and the signal ground. I want to tap into the the power at j/c c104 and tap into the ground at j/c c103 which are both on top of the cylinder head cover (page 14). Is this possible by just installing a wire into an open spot in each of these?
from what i believe j/c c104 is a 12v source to the sensors and that j/c c103 is the ground for the sensors.
thank you in advance
Old Jul 12, 2010 | 12:50 PM
Isn't the DX harness is also wired for two sensors? In that case you just need to extend the wires to reach the new sensor location. Tuner parts stores sell a ready made "sensor extension cable" for just that project.
Old Jul 12, 2010 | 01:32 PM
Glenn22's Avatar
Sorry i did not word what i have clearly enough. I have an ex engine harness which only has a connector for the upstream sensor. It is a dx car so i have no wiring for the downstream sensor since i would have to have an ex cabin harness to have the second connector.
spurabad1
Apr 23, 2012 06:27 AM
spurabad1
Apr 20, 2012 09:58 PM
spurabad1
Apr 2, 2012 05:26 PM
Peg_Leg
Sep 8, 2007 03:32 AM
