Dreaded P0420
Old Aug 20, 2008 | 08:37 PM
protegechris's Avatar
Default Dreaded P0420
New to the boards. I'm an accord guy myself, but a friend of mine has the P0420 code on her '97 Civic LX.. I'm curious as to whether there's any way to test whether this is the cat or the o2 sensor after the cat, figured I might find some tips from members around here.. so.. much appreciated
Old Aug 21, 2008 | 08:44 AM
macbeth18288's Avatar
Take it to autozone and they'll read the code and tell you which sensor is causing the problem
Old Aug 21, 2008 | 07:50 PM
The autozone print out said P0420 bank 1.. is that going to be the sensor nearest to the exhaust header?
Old Aug 21, 2008 | 08:06 PM
If you cannot find an exhaust leak upstream of the secondary O2 sensor, then the cat is bad. To verify a bad cat, remove and inspect:
Old Aug 22, 2008 | 09:14 AM
Chick decided to be an uber-bitch, I'll let her retarded unemployed boyfriend take care of it.
Thanks for the tips, guys! :P
ptw711
Mar 3, 2013 01:36 PM
Impulse2k1
Nov 7, 2006 04:48 PM
hans747
Sep 29, 2006 10:09 PM
kjreinha
Jan 5, 2006 04:32 PM
importcivicus
Jul 3, 2005 11:36 AM
