ebay fog light wiring harness help!
Old Jul 24, 2008 | 06:36 PM
Default ebay fog light wiring harness help!
The picture should sum it all up.
Old Jul 24, 2008 | 08:01 PM
Default RE: ebay fog light wiring harness help!
this is for the actual OEM one but it might be the same idk http://www.handa-accessories.com/civ...cfoglights.pdf
Old Jul 24, 2008 | 08:21 PM
Already referenced. Not the same. OEM Honda will turn fogs off when high beams are on, if I'm right. The plugs are different on this one.
Old Jul 24, 2008 | 08:31 PM
Search ftw? Onethread said the one with the inline fuse goes to an open constant on the fuse box and the other goes to an accessory on the fuse box. How can one tell which open slot is which?
Old Jul 24, 2008 | 08:35 PM
that makes sense
not sure how to tell
Old Jul 25, 2008 | 12:37 PM
bump before I go play with wires?
Old Jul 25, 2008 | 03:01 PM
New problem: The lights work, but the switch's internal lights stay on constantly. Any ideas?
Old Jul 26, 2008 | 05:00 AM
colby_666's Avatar
is that one plug for just the light on the switch, maybe needs a plug that turns the power to the switch light on while the fogs are on, but also the relay could do that i think, so its just an idea, do you have both pluged it somewhere?
Old Jul 26, 2008 | 08:58 AM
Both are plugged into the fuse box becauseboth have the same plug that fits those connectors. I wonder if the switch or relay went bad. I heard a click the very first time turned them on. I figured it was the relay, but the light wasn't on before that.
Old Jul 27, 2008 | 08:56 AM
KarTuneMan's Avatar
What pin on the relay is the red wire connected to?
