ECU Burned Out?
Old Jul 10, 2010 | 05:27 PM
  #31
Glenn22's Avatar
I have put about 200 miles on the car and so far everything has been smooth. the battery light has not been on and the charging system all checks out fine. only problem is i have a CEL's for p0135 and p0141 which are heater circuit malfunctions in both o2 sensors. Did Honda use different sensors from 02 to 03 which would cause it to throw a code? i know the the wiring is good because i checked for continuity before I installed the harness. These codes were not displayed on the old ecu.
Old Jul 10, 2010 | 05:37 PM
  #32
Is 10A dash fuse 4 blown?
Old Jul 10, 2010 | 06:37 PM
  #33
Glenn22's Avatar
the fuse has continuity and has 12.5v on both sides with the key in the ignition.
i understand why the p0141 code is being thrown because i have yet to hook up the downstream sensor because i need to wire in the plug to the harness and the ecu still, but the upstream sensor is installed.
i may have forgot to mention that i currently have sensors for the 2002 ex ecu installed with the new 03 ecu. i believe this may be my problem.
Old Jul 9, 2011 | 10:34 AM
  #34
Dseries03's Avatar
I just suffered the same problem...
1. check the bolts on your alternator, if those bolts come loose and the belt slips off the serp.. it will overcharge your PCM.. and force the car into Saftey/Limp mode...
2.You'll have to buy a new PCM or used.. Install it and get your keys matched with immobilizer and new PCM.. Honda Dealer is the only that can update or program Immoblizers..
3. Look forward to spending 800$ to 1000$.
4. Inspect Alternator BOLTS!!!!!! They will Break!!!
Old Jul 9, 2011 | 10:35 AM
  #35
Dseries03's Avatar
I have checked every fuse, ground, wire.... in my car, it is 100% alternator...
Old Jul 9, 2011 | 12:29 PM
  #36
Old thread.
juhaaan
Aug 8, 2011 12:07 PM
Maxxfli
Jun 26, 2009 07:04 AM
Lightsped
Aug 12, 2008 11:59 AM
01civic
Sep 29, 2006 12:03 AM
Toppers
Dec 11, 2005 01:08 PM
