ECU Needed? Part Number?
Old Jun 30, 2008 | 11:11 AM
04s2000's Avatar
Default ECU Needed? Part Number?
2001 CvicHX - CVT - Side Air Bags
The check engine light is on in my stock civic. Mechanic checked everthing, says i need a ECU.
Does anyone know the correct part number for this ecu?
Thanks
Old Jun 30, 2008 | 11:31 AM
Default RE: ECU Needed? Part Number?
It is very rare for the ECU to be bad.
Look here for possible vendors:
http://www.honda-tech.com/zerothread?id=2059889
Many on the forum also seem to purchase ECUs on eBay.
Old Jun 30, 2008 | 05:34 PM
04s2000's Avatar
Thanks for the info.
Do you know whereI can find the exact part number for the ECU so i can be sure it is the correct part.
CanI just plug in the replacementor doI need to do something first like flash the ECU?
Old Jun 30, 2008 | 07:54 PM
I agree with Ron, get a second opinion before replacing your ECU.
As for replacement, check the label on your ECU for the part number (assuming it is the original one and correct for the car). It just plugs in. Be sure to disconnect the battery before unplugging or replugging an ECU.
Old Jul 1, 2008 | 04:47 AM
scottdh20's Avatar
Member
i'll third that opinion, get a second opinion. ecus rarely have problems and when they do its ussually because the battery was not disconected during motor work. and when it was started there was a power surge. but i would have someone else check it out
regor
Sep 16, 2008 10:52 PM
joeblokeSIR2
Jan 9, 2008 04:18 AM
eriknba
Aug 10, 2007 04:27 AM
R8N
Jul 8, 2007 07:29 AM
nees1212
Aug 5, 2005 10:58 AM
